[GRASS-user] Re: Import vector: illegal filename
deagon
tylerdrudolph at gmail.com
Sun Jul 31 14:56:39 EDT 2011
Thank you for the feedback Glynn. Let's have a look at this simple example.
The input and output names are both 'NL1980s'.
The column names are as follows: 'id', 'day', 'x', 'y', 'col_type', 'herd',
'year', 'month', 'coords_x1', 'coords_x2'
All names are less than 10 characters and only use letters, digits and/or
underscore....
I don't believe any are SQL keywords (please correct me if I'm wrong)....
Do you see any errors with this? Here is the message I get:
v.in.ogr -o dsn=C:/GIS/NL/NL1980s.shp output=NL1980s snap=-1 min_area=0.0001
Illegal filename. Character not allowed.
Over-riding projection check
Layer: NL1980s
Counting polygons for 8036 features...
Importing map 8036 features...
Building topology for vector map ...
Registering primitives...
1000 2000 3000 4000
5000 6000 7000 8000
8036 primitives registered
8036 vertices registered
Number of nodes: 6466
Number of primitives: 8036
Number of points: 8036
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: -
Number of isles: -
Vector map not found
Finished with error
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Import-vector-illegal-filename-tp6638439p6638853.html
Sent from the Grass - Users mailing list archive at Nabble.com.
