[GRASS-user] i.spectral error
Markus Neteler
neteler at osgeo.org
Fri Jun 3 08:00:11 EDT 2011
2011/6/3 Gaspar Reyes Póndigo <gos47 at hotmail.com>:
> Hi, Dear grass-user colleague
> I want obtain a spectral response of four images with i.spectral, but when
> run the code, this send me a error. I have gnuplot version 4.4
> (installed from macport). How to can i solve this error? Thank in advance
> i.spectral -i -m raster=Acrf_b1,Acrf_b2,Acrf_2010_b3,Acrf_2010_b4
> # THE CODE
> Buttons:
> Left: where am i
> Middle: draw to/from here
> Right: quit this
> EAST: NORTH:
> 731739.14835165 1758715.54945055
> 731893.26923077 1755787.25274725
> set data style lines # THIS IS THE ERROR MESSAGE
> "spectrum.gnuplot", line 10: Unrecognized option. See 'help set'.
Yes: the correct syntax is this:
set style data lines
I have fixed it in all GRASS versions.
In your local copy, you can simply apply this change with a text
editor, even in the installed version since it is just a script:
(the line numbers are at the left side, the fix is easy to do).
http://trac.osgeo.org/grass/changeset/46545
Thanks for catching it,
Markus
