[GRASS-user] r.colors -e for G3d?
Soeren Gebbert
soerengebbert at googlemail.com
Wed Jun 15 02:36:40 EDT 2011
Hello Hamish,
just a short note:
I currently rework the g3d library and the related modules to use the
correct coordinate system (x, y, z -> right hand side cube). So all
modules which convert raster to raster3d and vis versa are implemented
in a wrong way. The r3.out.vtk export module is wrong too, it flips
the y coordinate so the result looks reasonable in Paraview. :/
While doing this i plan to implement two more modules: r3.retile and
r3.colors. r3.colors can be used to assign a color table to a raster3d
map (its an enhancement to r.colors to support 3d raster too, like
r.univar and r3.univar). Because g3d uses the same color table and
functions as the raster library these color tables can be exchanged
between raster and raster3d maps. Maybe this is the function you are
looking for?
Nice to hear that you plan to write a convert tool to use grass color
tables in VTK too. Can you please provide your code when its finished,
because this functionality is still missing in the vtk-grass-bridge.
I hope to finish the g3d library work this or next week to finally
start with full temporal support in grass7.
Best regards
Soeren
2011/6/15 Hamish <hamish_b at yahoo.com>:
> Hi,
> I've got a 3D raster with a very skewed distribution.
> For viewing the slices (r3.to.rast) I'd like to use a
> single set of color rules for all of the z-levels.
> So I'd like to run the ever-amazing 'r.colors -e' to
> equalize over the full distribution, but how to do
> that for all the z-level slices at once?
> ideas:
> -r.region translate them and then patch them all
> together on the same horizontal plane, calc the color
> rules, then apply the mosaic's set of rules to all
> the original slices.
> -same but interleave the slices at 1/n resolution
> instead of r.region + r.patch.
> -use `r3.univar -e percentile=a,b,c,d,...` to re-
> create what `r.colors -e` does, perhaps poorly.
> (is there a set number of histogram steps r.colors -e
> breaks things up into? the 256 from lib/gis/color_hist.c?)
> -modify r.colors's get_fp_stats() to scan over
> multiple input rasters in a loop?
> The rules file I'd like to use starts out with 263
> levels, so more than I'd like to interpolate by
> hand.
> (grass-addons/raster/r.colors.tools/palettes/palette_sst.gcolors)
> my data is all > 0.0
> once I have that I'd like to write an addon module
> which converts a grass color table to a VTK .xml
> color table, so they can be used there too, and also
> figure out how to auto-set NVIZ G3D isosurface
> colors from them.
> thanks,
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
