[GRASS-user] Re: Re: How to draw the earthquake-magtintude map...
    sgw00412 at nifty.com
    Mon Jun 20 00:26:01 EDT 2011
Dear Hamish and all
Than you for some useful advices.
I done upgrade grass versio from 6.4.0 to 6.4.1.
> try upgrading to 6.4.1, and the size_column= option should
> start to work. (n.b. adding this option was actually inspired by
> the desire to vary symbol size for earthquake plots)
> also you will find in GRASS 6.4.1 the new extra/ring symbol,
> which is similar to basic/circle with fill_color=none, but
> allows the dynamic color setting to colorize the border line,
> not the fill area. (so the fill area does not mask smaller quakes
> at close epicenters)
great !
Also, I am bigginer user of grass and unix shell.
I made the script referring to your advices as follows;
Thank you !
Best
Yasuo shimada ( japan weather association )
< shell script >
http://homepage1.nifty.com/8856/grass_quake_en.html
< quake map 13. June >
http://homepage1.nifty.com/8856/gg20110613.png
< quake map 14. June >
http://homepage1.nifty.com/8856/gg20110614.png
