[GRASS-user] faster than v.rast.stats
Markus Metz markus.metz.giswork at googlemail.com
Wed Jun 22 03:05:30 EDT 2011
On Tue, Jun 21, 2011 at 6:10 PM, Frederico Mestre
<mestre.frederico at gmail.com> wrote:
> Hello,
> The vector I've got is a grid 10x10 km, but it has some small irregular
> shapes, do you think it would be adequate for raster calculation?
Since you want to retrieve statistics from raster maps for vector
areas, the resolution of the raster maps should be used for the
computations. I think both v.rast.stats and v.rast.stats2 align the
region to the raster resolution. It can happen that areas smaller than
a single cell are skipped, because that level of detail is not present
in the raster map.
> And I need to calculate a large number of variables, for a large geographic
> area, using this vector and underlying rasters.
Use v.rast.stats2. It is much faster for vector maps with many areas
and also has fewer bugs than v.rast.stats. v.rast.stats and
v.rast.stats2 are both shell scripts, so you can just download
v.rast.stats2 and replace the existing v.rast.stats if installation
via g.extension fails.
Markus M
