[GRASS-user] rgb-his, his-rgb for 16-bit
Christian Röttger
chris.roettger at uni-muenster.de
Wed Jun 22 05:04:57 EDT 2011
Hello,
i wonder if the rgb-his and vice versa works with more than 8-bit
images. I found in the mail archive that it should be fixed in 6.4 but
it doesn't work in grass 6.4.2 RC2 nor 7.
The aim is to pan sharpen quickbird images.yes, it can be done by using
brovey transformation. But i think rgb-his/his-rgb should also work
without transforming the image to 8-bit before.
greetz,
christian
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname : smime.p7s
Dateityp : application/pkcs7-signature
Dateigr??e : 6040 bytes
Beschreibung: S/MIME Cryptographic Signature
URL : http://lists.osgeo.org/pipermail/grass-user/attachments/20110622/99e85596/smime-0001.bin
