[GRASS-user] Re: r.stream.extract with external flow accumulation
maps
jentjr
jentjr at gmail.com
Mon Jun 27 13:44:56 EDT 2011
Thank you for the replies. I set the region to the flow accumulation map, and
I still received the error though. Here is the region output for both the
elevation and flow accumulation maps
Elevation:
GRASS 6.4.1 (NAD83_GRS80_LCC):~ > g.region -p rast=elev_cm at hydrology
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: grs80
north: 276735
south: 182265
west: 111075
east: 398265
nsres: 30
ewres: 30
rows: 3149
cols: 9573
cells: 30145377
Flow accumulation:
GRASS 6.4.1 (NAD83_GRS80_LCC):~ > g.region -p rast=fac at hydrology
zone: 0
datum: nad83
ellipsoid: grs80
north: 276705
south: 182025
west: 110445
east: 399105
nsres: 30
ewres: 30
rows: 3156
cols: 9622
cells: 30367032
I also tried setting a mask
r.mapcalc 'new_fac=if(fac==null(),null(),1)'
r.mask input=new_fac
GRASS 6.4.1 (NAD83_GRS80_LCC):~ > r.stream.extract
elevation=elev_cm at hydrology accumulation=fac at hydrology stream_rast=rstream5K
stream_vect=rstream5K threshold=5000 direction=rstream5K_fdr
ERROR: Accumulation map does not match elevation map!
[Raster MASK present]
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-stream-extract-with-external-flow-accumulation-maps-tp6518518p6521518.html
Sent from the Grass - Users mailing list archive at Nabble.com.
