[GRASS-user] Re: r.stream.extract with external flow accumulation maps
jentjr jentjr at gmail.com
Mon Jun 27 23:06:28 EDT 2011
It worked! I also tried it without changing the spatial extent of the map and
it worked. So, I just needed to set the null values to zero.
Thanks for the patience,
Justin Jent
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-stream-extract-with-external-flow-accumulation-maps-tp6518518p6523487.html
Sent from the Grass - Users mailing list archive at Nabble.com.
