[GRASS-user] Re: Limit d.raster with vector map
Nick Jachowski
njachowski at gmail.com
Thu Jun 30 12:36:36 EDT 2011
I would do what Daniel said, but use the raster (use command v.to.rast) as a
mask (use command r.mask) to limit the displayed area to the vector map
area.
On Thu, Jun 30, 2011 at 9:40 PM, Daniel Lee <Lee at isi-solutions.org> wrote:
> I would do the following, assuming you've got an area vector that's
> covering
> the raster data you want to show:
> 1. Convert the vector to a raster with r.to.vect
> 2. Reclassify it so that it's got only two values: 1 and NoData.
> 3. Multiply the reclassified raster with the raster data that you want to
> limit to the area of the vector. The old values will be preserved in the
> resulting map because x * 1 = x, but everything that's not collocated with
> the vector map will be removed because it's multiplied with NoData.
> http://osgeo-org.1803224.n2.nabble.com/Limit-d-raster-with-vector-map-tp6533406p6533536.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110630/7c63c56a/attachment.html
