[GRASS-user] db.execute where condition
Rich Shepard rshepard at appl-ecosys.com
Mon Mar 7 14:27:12 EST 2011
On Mon, 7 Mar 2011, Frans-Joost Boogert wrote:
> I removed the 'within' quotes and the command line now looks like this:
> echo 'UPDATE landuse_table SET FEATURE_ID=1 WHERE
> FEATURE=Grazing_land'|db.execute driver=dbf database=$database
Frans-Joost,
   You still don't have the correct syntax. Look at the examples on the
db.execute page:
Update attribute entries to new value based on SQL rule:
echo "UPDATE roads SET travelcost=5 WHERE cat=1" | db.execute
   Notice that the entire expression to be echoed is in double quotes. Other
examples on that page show the column values are in single quotes. Try:
echo "UPDATE landuse_table SET FEATURE_ID=1 WHERE FEATURE='Grazing_land'" | db.execute
after setting the driver and database name separately.
Rich
