[GRASS-user] Some thoughts on wxGUI (GRASS Community Sprint)
Markus Neteler
neteler at osgeo.org
Thu Mar 10 04:52:20 EST 2011
On Thu, Mar 10, 2011 at 9:31 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/3/10 Maris Nartiss <maris.gis at gmail.com>:
>> having console output in same window with layers is one of those small
>> tibits that make new GUI unproductive for daily use. Yeah, it might
>> hava bright future, but unless I can undock comand output to separate
>> window, it will continue to suck.
> I don't see any fundamental troubles here, at least with working key
> shortcuts to switch between layer tree and output area.
>> My proposal - do not try to copy ArcGIS/QGIS. With current manpower
>> and legacy we will not be able to do on same level or better. If it's
>> so - better don't. Keep GRASS different. Being able to drag separate
>> windows to different monitors etc. is one of GRASS strenghts.
> Good point.
Let the user decide... obviously there are two groups. So to make it optional
would be the best solution.
Markus
