[GRASS-user] db.out.ogr: Syntax Correction
Helmut Kudrnovsky
hellik at web.de
Mon Mar 14 15:08:01 EDT 2011
Hi
>> Why don't you try with g.copy?
> My reading of the man page is that g.copy copies maps from a non-current
>mapset to the current one. I don't see how to use this to copy attribute
>data from dbf to pg.
db.connect - Prints/sets general DB connection for current mapset and exits.
http://grass.osgeo.org/grass64/manuals/html64_user/db.connect.html
just an example:
location abc with two mapsets
mapset dbfASdb <= with dbf as DB set by db.connect
mapset pgASdb <= with pg as DB set by db.connect
if you g.copy your vectors from mapset dbfASdb to mapset pgASdb, all the attributes are also
copied from dbf to pg.
HTH
Helmut
___________________________________________________________
WEB.DE DSL Doppel-Flat ab 19,99 €/mtl.! Jetzt mit
gratis Handy-Flat! http://produkte.web.de/go/DSL_Doppel_Flatrate/2
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110314/396d2ee1/smime.bin
