[GRASS-user] batch file processiong stops with some db-commands
Markus Neteler
neteler at osgeo.org
Mon Mar 14 17:36:24 EDT 2011
On Sat, Mar 12, 2011 at 5:48 PM, Matthias Klingel
<matthias.klingel at web.de> wrote:
> Dear grass users,
> in wingrass 6.4.1 (or at least on my machine), processing of batch files with grass commands stops after executing v.db.addtable, v.db.addcol, v.db.addcol, v.db.dropcol and their db.* equivalents. The rest of the batch file will not be processed. Of course, there is a workaround using SQL commands with db.execute, but this is substantially more typing work. Anybody has the same problem and knows how to fix it?
Do you use the DBF driver? Perhaps you are hit by this bug:
http://trac.osgeo.org/grass/ticket/1308
Hopefully solved soon...
Markus
