[GRASS-user] Error while removing file
António Rocha
antonio.rocha at deimos.com.pt
Wed Mar 16 09:17:50 EDT 2011
Hi again :)
Ok the main problem is that I'm using r.statistics with base=new_clump10
and cover= myscript.tmpV1
If I try to remove new_clump I get:
g.remove -f rast=new_clump10 at area
[new_clump10 at area@area] is a base map for [myscript.tmpV1 at area]. Remove
forced.
Removing raster <LULC_new_clump10 at National>
misc: couldn't be removed
So it wasn't removed. My question is:
1- Why it's repeating the Mapset information (new_clump10 at area@area)
That is odd right? Maybe that is what is messing with the system
Thanks
Antonio
Glynn Clements wrote:
> António Rocha wrote:
>> Ok it has removed but when I try to write over that file I get errors
>> like Permission DENIED.
>> WHat can I do to fix this?
> Ensure that all files and directories within the mapset directory are
> owned by you, and have the necessary permissions (read and write for
> files, read, write and execute for directories).
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5957 (20110316) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
