[GRASS-user] Installing Add-ons on a Mac
William Kyngesburye woklist at kyngchaos.com
Mon Mar 21 10:04:57 EDT 2011
Way back before g.extension, I wasn't satisified with GEM, and there wasn't much interest in fixing it up, so I added 'modbuild' to the Mac package.
It's still there, though it's not obvious (it's breifly mentioned in one of the readmes).  Find it in /Library/GRASS/6.4.  Copy it to your home folder (to avoid permissions problems) and follow the instructions in the readme in that folder.
One additional thing you need to do, discovered recently, is copy all the static *.a libraries from the GRASS application (/Applications/GRASS-6.4.app/Contents/MacOS/lib) to the modbuild/Modules/lib folder.
Note that installation of the module is not automatic.
On Mar 21, 2011, at 2:36 AM, Johannes Radinger wrote:
> Hello,
> as it is not posssible at the moment to install add-on modules on a mac via the g.extension (on GRASS GIS 6.5SVN and 7SVN) I'd like to ask you if there is any other way?
> Maybe you can explain me step by step how to install an add-on without g.extension on my mac. I'd like to install the r.stream.* packages and the r.fuzzy.system.
> Please help me as I need both packages for my work.
> Thank you
> Johannes
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
