[GRASS-user] Re: How to extract z-coordiante and write it into
attribute table?
TimNorwey
timmy_weyrer at live.at
Wed Mar 23 12:25:50 EDT 2011
> Tim,
> the relative dispersion of our answers might be due to a lack of
> description of what your actually want to do.
> If you're still stuck, try to re-expose your problem clearly.
Sry for that. I will try it again.
A basis I have a .csv-file including LIDAR points. I imported that csv-file
via v.in.ascii into location A. Because I need this data in another
projection, I created a location B and used v.proj to reproject the point
cloud from location A to location B.
Now I would need the z-coordinate as attribute to it´s corresponding point.
As you recommended I tried to add the tables (v.db.addcol) and this worked.
Then I wanted to fill the columns using v.to.db. But this didn´t work.
Then I deleted all the files and imported the csv-file again using the same
workflow as before. Now I have the problem that there is no corresponding
table in the dbf-directory and so I cannot try to add columns as before.
I hope it´s all a little bit clearer.
Thanks,
tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-extract-z-coordiante-and-write-it-into-attribute-table-tp6199821p6200870.html
Sent from the Grass - Users mailing list archive at Nabble.com.
