[GRASS-user] Re: How to extract z-coordiante and write it into attribute table?
TimNorwey timmy_weyrer at live.at
Wed Mar 23 15:39:32 EDT 2011
> Could there be other extraneous values somewhere in the original ascii
> file? Maybe rows with an extra comma, or other characters? Can you make
> a bunch of rows available online somewhere so that we can have a look?
Returns v.in.ascii no error if I´m importing something that isn´t in the
right format?
Here a part of my csv file:
http://osgeo-org.1803224.n2.nabble.com/file/n6201677/testData.csv
testData.csv
> Another point you might want to take advantage of: v.in.ascii has an
> option (-z) to create a 3D vector. This means that each point's geometry
> consists of x,y, and z. So you then have the elevation available even if
> the values are not actually in the attribute table. For example, you can
> interpolate a dem from a 3D vector with no attribute table at all.
Thank you for the hint, but I used the -z option. I need the elevation in
addition.
Thanks,
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-extract-z-coordiante-and-write-it-into-attribute-table-tp6199821p6201677.html
Sent from the Grass - Users mailing list archive at Nabble.com.
