[GRASS-user] r.rescale - float instead of integer?
Johannes Radinger
JRadinger at gmx.at
Thu Mar 24 03:31:56 EDT 2011
Am 24.03.2011 um 07:34 schrieb Hamish:
> Johannes wrote:
>> I think r.mapcalc is probably the best solution, but as I don't know
>> the maximum value in every case (I've to process several maps), I
>> wanted
>> to automatize. Probably I've to write a script to read the max
>> value and
>> parse it to the mapcalc function.
> g.mlist + 'r.info -r' in a loop.
I thought more about the pipe command in python like:
p = grass.pipe_command('r.stats',flags='c',input='map')
result = {}
for line in p.stdout:
val,count = line.strip().split()
result[int(val)] = int(count)
p.wait()
but in combination with r.info to read the max value, but I don't
know yet how
to realize it (the code in the for loop of p.stdout).
maybe someone has an idea...
cheers
/johannes
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110324/ef3ec25d/attachment.html
