[GRASS-user] Re: Import Interlis format
Patrick S.
patrick_GIS at gmx.ch
Fri Mar 25 04:53:55 EDT 2011
Thanks Andreas,
But it just doesn't seem a right approach to me to convert a topological
format into a simple feature format to import it to GRASS. I am speaking
of some 300.000 polygons of buildings and X00.0000 parcels, which
created a lot of topological problems when I imported from shapefiles.
That's why I did ask the dataowner for the INTERLIS format.
Isn't there any other solution or exchange format that is topological?
Regards, Patrick
P.S. sorry for the late answer- but I was off for 2 Weeks
On 03/12/2011 12:28 AM, grass-user-request at lists.osgeo.org wrote:
> Message: 9
> Date: Fri, 11 Mar 2011 21:39:20 +0100
> From: Andreas Neumann<a.neumann at carto.net>
> Subject: Re: [GRASS-user] interlis import
> To:grass-user at lists.osgeo.org
> Message-ID:<4D7A8878.6050306 at carto.net>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi Patrick,
> I wouldn't try to open Interlis files directly in GRASS. You are better
> off converting them to an intermediate format or database, e.g.
> spatialite, PostgreSQL, GML, etc. and work from there.
> If you open the files directly, performance will be bad.
> btw: Interlis consists of two files:
> 1. .ili file (contains the data model: topics, tables, columns, data
> types, domain lists, etc.)
> 2. .itf file (the raw data: geometry and attribute data). - itf means
> "interlis transfer format"
> You always need both files.
> Here are one or two examples:http://gis.hsr.ch/wiki/HowTo_OGR2OGR
> Good luck,
> Andreas
> On 3/11/11 8:00 PM, Patrick S. wrote:
>> > Dear List,
>> > does someone have experience in importing the topological format
>> > INTERLIS to GRASS?
>> > It seems to need an .ili file, that will define polygons, lines and
>> > points, but I don't see how to integrate this one in the v.in.ogr
>> > command.
>> > I managed to use ogr2ogr and tested conversion to shapefile. This one
>> > uses the java interpreter ili2c.jar. (see:
>> > http://www.gdal.org/ogr/drv_ili.html). It will only work if the .ili
>> > is intergrated as in the command:
>> > ogr2ogr -f "ESRI Shapefile" shpdir
>> > /home/order/filename.itf,/home/order/description.ili
>> > When I import the .itf to GRASS it will only create lines instead of
>> > areas. Same result for conversion with ogr2ogr mentioned above when
>> > the .ili is not integrated.
>> > Any Feedback would be helpful.
>> > Patrick
>> > P.S. Testfiles can be foundhttp://www.interlis.ch/
>> > _______________________________________________
>> > grass-user mailing list
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
