[GRASS-user] Using r.buffer on image with geographic coordinates
    Ned Horning
    horning at amnh.org
    Mon Mar 28 06:39:41 EDT 2011
Markus,
Thanks for fixing the code. I managed to compile v.buffer and I ran it
in the grass65 terminal window and these are the errors I got. There
were several of the "Next edge was visited...." messages but I only cut
out the last couple. Any idea what the problem might be? I'm running on
64 bit Ubuntu.
All the best,
Ned
WARNING: Next edge was visited but it is not the first one !!! breaking
          loop
          loop
          loop
          loop
*** glibc detected *** d.vect: free(): invalid next size (normal):
0x00000000013a5fc0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x775b6)[0x7fc0f26965b6]
/lib/libc.so.6(cfree+0x73)[0x7fc0f269ce83]
/usr/local/grass-6.5.svn/lib/libgrass_vect.6.5.svn.so(Vect_destroy_line_struct+0x28)[0x7fc0f424f638]
d.vect(plot1+0xb0a)[0x40876a]
d.vect(main+0x1314)[0x4072d4]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7fc0f263dc4d]
d.vect[0x403cd9]
======= Memory map: ========
00400000-0040c000 r-xp 00000000 08:05 206110
/usr/local/grass-6.5.svn/bin/d.vect
0060b000-0060c000 r--p 0000b000 08:05 206110
0060c000-0060d000 rw-p 0000c000 08:05 206110
01398000-013b9000 rw-p 00000000 00:00 0
[heap]
7fc0e4000000-7fc0e4021000 rw-p 00000000 00:00 0
7fc0e4021000-7fc0e8000000 ---p 00000000 00:00 0
7fc0e97cd000-7fc0e97d9000 r-xp 00000000 08:05 531120
/lib/libnss_files-2.11.1.so
7fc0e97d9000-7fc0e99d8000 ---p 0000c000 08:05 531120
7fc0e99d8000-7fc0e99d9000 r--p 0000b000 08:05 531120
7fc0e99d9000-7fc0e99da000 rw-p 0000c000 08:05 531120
7fc0e99da000-7fc0e99e4000 r-xp 00000000 08:05 531542
/lib/libnss_nis-2.11.1.so
7fc0e99e4000-7fc0e9be3000 ---p 0000a000 08:05 531542
7fc0e9be3000-7fc0e9be4000 r--p 00009000 08:05 531542
7fc0e9be4000-7fc0e9be5000 rw-p 0000a000 08:05 531542
7fc0e9be5000-7fc0e9bed000 r-xp 00000000 08:05 527981
/lib/libnss_compat-2.11.1.so
7fc0e9bed000-7fc0e9dec000 ---p 00008000 08:05 527981
7fc0e9dec000-7fc0e9ded000 r--p 00007000 08:05 527981
7fc0e9ded000-7fc0e9dee000 rw-p 00008000 08:05 527981
7fc0e9dee000-7fc0e9df1000 r-xp 00000000 08:05 523508
/lib/libgpg-error.so.0.4.0
7fc0e9df1000-7fc0e9ff0000 ---p 00003000 08:05 523508
7fc0e9ff0000-7fc0e9ff1000 r--p 00002000 08:05 523508
7fc0e9ff1000-7fc0e9ff2000 rw-p 00003000 08:05 523508
7fc0e9ff2000-7fc0ea002000 r-xp 00000000 08:05 134688
/usr/lib/libtasn1.so.3.1.7
7fc0ea002000-7fc0ea201000 ---p 00010000 08:05 134688
7fc0ea201000-7fc0ea202000 r--p 0000f000 08:05 134688
7fc0ea202000-7fc0ea203000 rw-p 00010000 08:05 134688
7fc0ea203000-7fc0ea21c000 r-xp 00000000 08:05 134634
/usr/lib/libsasl2.so.2.0.23
7fc0ea21c000-7fc0ea41b000 ---p 00019000 08:05 134634
7fc0ea41b000-7fc0ea41c000 r--p 00018000 08:05 134634
7fc0ea41c000-7fc0ea41d000 rw-p 00019000 08:05 134634
7fc0ea41d000-7fc0ea433000 r-xp 00000000 08:05 531562
/lib/libresolv-2.11.1.so
7fc0ea433000-7fc0ea632000 ---p 00016000 08:05 531562
7fc0ea632000-7fc0ea633000 r--p 00015000 08:05 531562
7fc0ea633000-7fc0ea634000 rw-p 00016000 08:05 531562
7fc0ea634000-7fc0ea636000 rw-p 00000000 00:00 0
7fc0ea636000-7fc0ea638000 r-xp 00000000 08:05 523515
/lib/libkeyutils-1.2.so
7fc0ea638000-7fc0ea837000 ---p 00002000 08:05 523515
7fc0ea837000-7fc0ea838000 r--p 00001000 08:05 523515
7fc0ea838000-7fc0ea839000 rw-p 00002000 08:05 523515
7fc0ea839000-7fc0ea840000 r-xp 00000000 08:05 134268
/usr/lib/libkrb5support.so.0.1
7fc0ea840000-7fc0eaa3f000 ---p 00007000 08:05 134268
7fc0eaa3f000-7fc0eaa40000 r--p 00006000 08:05 134268
7fc0eaa40000-7fc0eaa41000 rw-p 00007000 08:05 134268
7fc0eaa41000-7fc0eaa65000 r-xp 00000000 08:05 132675
/usr/lib/libk5crypto.so.3.1
7fc0eaa65000-7fc0eac65000 ---p 00024000 08:05 132675
7fc0eac65000-7fc0eac66000 r--p 00024000 08:05 132675
7fc0eac66000-7fc0eac67000 rw-p 00025000 08:05 132675
7fc0eac67000-7fc0eac7e000 r-xp 00000000 08:05 527976
/lib/libnsl-2.11.1.so
7fc0eac7e000-7fc0eae7d000 ---p 00017000 08:05 527976
7fc0eae7d000-7fc0eae7e000 r--p 00016000 08:05 527976
7fc0eae7e000-7fc0eae7f000 rw-p 00017000 08:05 527976
7fc0eae7f000-7fc0eae81000 rw-p 00000000 00:00 0
7fc0eae81000-7fc0eaef6000 r-xp 00000000 08:05 523504
/lib/libgcrypt.so.11.5.2
7fc0eaef6000-7fc0eb0f5000 ---p 00075000 08:05 523504
7fc0eb0f5000-7fc0eb0f6000 r--p 00074000 08:05 523504
7fc0eb0f6000-7fc0eb0f9000 rw-p 00075000 08:05 523504
7fc0eb0f9000-7fc0eb195000 r-xp 00000000 08:05 134182
/usr/lib/libgnutls.so.26.14.12
7fc0eb195000-7fc0eb394000 ---p 0009c000 08:05 134182
7fc0eb394000-7fc0eb39a000 r--p 0009b000 08:05 134182
7fc0eb39a000-7fc0eb39b000 rw-p 000a1000 08:05 134182
7fc0eb39b000-7fc0eb3a8000 r-xp 00000000 08:05 132150
/usr/lib/liblber-2.4.so.2.5.4 100%
Writting buffers...
  100%
Building topology for vector map <testBuf2>...
Registering primitives...
1435962 primitives registered
115977416 vertices registered
Number of nodes: 1435838
Number of primitives: 1435962
Number of points: 0
Number of lines: 0
Number of boundaries: 1435962
Number of centroids: 0
Number of areas: -
Number of isles: -
Snapping boundaries...
Killed
GRASS 6.5.svn (NHD_Test):~ >
On 03/27/2011 02:51 PM, Markus Neteler wrote:
> On Sun, Mar 27, 2011 at 3:57 PM, Ned Horning<horning at amnh.org>  wrote:
>> Hi Markus,
>> Thanks for your help. I am trying to follow your instruction but ran into a
>> problem compiling v.buffer. I used svn to download grass 6.5 into
>> /usr/local/src and it appears to have compiled just fine and grass65 seems
>> to be working. To compile v.buffer I tried:
>> sudo make MODULE_TOPDIR=/usr/local/grass-6.5.svn/
>> from the /usr/local/src/grass6_devel/vector/v.buffer directory but that
>> didn't work. I pasted the error message below.
> I have fixed to typo style bugs. Now it compiles, please try again.
> Markus
