[GRASS-user] Problem with Python Scripts and grass.script (GRASS
	6.5SVN) on Mac
    Johannes Radinger
    JRadinger at gmx.at
    Tue Mar 29 11:35:47 EDT 2011
Hello Michael,
thank you for your answer and your tip with the debugging code,
but it doesn't matter where I put it, I fail. I that case grass doesn't
open anymore the interactive menu (from g.parser) for that script and I just get the error:
my program gets this far
ERROR: Required parameter <newmap> not set:
        (output)
ERROR: Required parameter <elevation> not set:
        (input 1)
ERROR: Required parameter <geology> not set:
        (input 2)
if I leave the debugging code out, the interactive menu pops up and I can set the parameters, but nothing is afterwards processed.
what am I doing wrong?
/johannes
-------- Original-Nachricht --------
> Datum: Tue, 29 Mar 2011 07:40:28 -0700
> Von: Michael Barton <Michael.Barton at asu.edu>
> An: grass-user grass-user <grass-user at lists.osgeo.org>, Johannes Radinger <JRadinger at gmx.at>
> Betreff: [GRASS-user] Problem with Python Scripts and grass.script 	(GRASS	6.5SVN) on Mac
> Hi Johannes,
> Sorry I couldn't get back to you sooner. But it seems like others have
> told you about the line ending issue. That's a real problem because most
> people (myself included) will want to start out by copying an example program
> from the GRASS site.
> ...and it will utterly fail to run.
> Anyway, now that your got it started, it is a debugging issue. Put in some
> debugging code like...
> print 'my program gets this far'
> ...at different places to see where it is getting stuck. This is tedious
> but always seems needed.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Mar 29, 2011, at 3:25 AM, <grass-user-request at lists.osgeo.org> wrote:
> > Date: Tue, 29 Mar 2011 11:11:12 +0200
> > From: "Johannes Radinger" <JRadinger at gmx.at>
> > Subject: [GRASS-user] Problem with Python Scripts and grass.script
> > To: grass-user at lists.osgeo.org
> > Message-ID: <20110329091112.282590 at gmx.net>
> > Content-Type: text/plain; charset="utf-8"
> > Hello Grass users!
> > I am working with GRASS 6.5 SVN (r45714, last weeks source) and try to
> run Python Scripts. After I solved the problem with the line endings, GRASS
> seems to be able to read my scripts (via launch script...). At least the
> interactive interface pops up correctly (it seems g.parser can read all my
> options etc.), but after executing it nothing happens and nothing is
> processed. I tried it with mapcalc but also with r.thin (one input, one output, so
> very simple).
> > I don't know what is the problem or how can I check what the problem
> is...
> > ...what I've tried already and which may cause the problem is that I
> cannot import grass.script (import grass.script) in the Terminal (pyhton)
> and/or IDLE... it says: module not found...
> > Just for your information I run GRASS on a Apple Mac Snow Leopard
> (10.6.6)
> > with Python 2.6.6.
> > /johannes
> > NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> > Jetzt informieren: http://www.gmx.net/de/go/freephone
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
