[GRASS-user] Using r.buffer on image with geographic coordinates
Ned Horning horning at amnh.org
Wed Mar 30 07:52:27 EDT 2011
Thanks for the help compiling with v.buffer. I think I'm running the
correct version now but the function still does not complete properly. I
pasted the last several lines from the terminal screen below. I have a
feeling I ran out of memory. Any ideas about what I can try next?
Ned
D0/0: sa: 22
D0/0: current: 22
D0/0:   current = 29, last = 30, lcount = 1
D0/0: sa: 28
D0/0: current: 28
D0/0:   current = 29, last = 34, lcount = 1
D0/0: sa: 28
D0/0: current: 28
Building parts of topology...
Building topology for vector map <testBuf>...
Registering primitives...
1433691 primitives registered
119731336 vertices registered
Number of nodes: 1433605
Number of primitives: 1433691
Number of points: 0
Number of lines: 0
Number of boundaries: 1433691
Number of centroids: 0
Number of areas: -
Number of isles: -
Snapping boundaries...
Killed
GRASS 6.5.svn (NHD_Test):~ >
GRASS 6.5.svn (NHD_Test):~ > *** glibc detected *** d.vect: free():
invalid next size (normal): 0x0000000001a77fc0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x775b6)[0x7f32f1a055b6]
/lib/libc.so.6(cfree+0x73)[0x7f32f1a0be83]
/usr/local/grass-6.5.svn/lib/libgrass_vect.6.5.svn.so(Vect_destroy_line_struct+0x28)[0x7f32f35be638]
d.vect(plot1+0xb0a)[0x40876a]
d.vect(main+0x1314)[0x4072d4]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7f32f19acc4d]
d.vect[0x403cd9]
======= Memory map: ========
00400000-0040c000 r-xp 00000000 08:05 206108
/usr/local/grass-6.5.svn/bin/d.vect
0060b000-0060c000 r--p 0000b000 08:05 206108
0060c000-0060d000 rw-p 0000c000 08:05 206108
01a6a000-01a8b000 rw-p 00000000 00:00 0
[heap]
7f32e4000000-7f32e4021000 rw-p 00000000 00:00 0
7f32e4021000-7f32e8000000 ---p 00000000 00:00 0
7f32e8b3c000-7f32e8b48000 r-xp 00000000 08:05 531120
/lib/libnss_files-2.11.1.so
7f32e8b48000-7f32e8d47000 ---p 0000c000 08:05 531120
7f32e8d47000-7f32e8d48000 r--p 0000b000 08:05 531120
7f32e8d48000-7f32e8d49000 rw-p 0000c000 08:05 531120
7f32e8d49000-7f32e8d53000 r-xp 00000000 08:05 531542
/lib/libnss_nis-2.11.1.so
7f32e8d53000-7f32e8f52000 ---p 0000a000 08:05 531542
7f32e8f52000-7f32e8f53000 r--p 00009000 08:05 531542
7f32e8f53000-7f32e8f54000 rw-p 0000a000 08:05 531542
7f32e8f54000-7f32e8f5c000 r-xp 00000000 08:05 527981
/lib/libnss_compat-2.11.1.so
7f32e8f5c000-7f32e915b000 ---p 00008000 08:05 527981
7f32e915b000-7f32e915c000 r--p 00007000 08:05 527981
7f32e915c000-7f32e915d000 rw-p 00008000 08:05 527981
7f32e915d000-7f32e9160000 r-xp 00000000 08:05 523508
/lib/libgpg-error.so.0.4.0
7f32e9160000-7f32e935f000 ---p 00003000 08:05 523508
7f32e935f000-7f32e9360000 r--p 00002000 08:05 523508
7f32e9360000-7f32e9361000 rw-p 00003000 08:05 523508
7f32e9361000-7f32e9371000 r-xp 00000000 08:05 134688
/usr/lib/libtasn1.so.3.1.7
7f32e9371000-7f32e9570000 ---p 00010000 08:05 134688
7f32e9570000-7f32e9571000 r--p 0000f000 08:05 134688
7f32e9571000-7f32e9572000 rw-p 00010000 08:05 134688
7f32e9572000-7f32e958b000 r-xp 00000000 08:05 134634
/usr/lib/libsasl2.so.2.0.23
7f32e958b000-7f32e978a000 ---p 00019000 08:05 134634
7f32e978a000-7f32e978b000 r--p 00018000 08:05 134634
7f32e978b000-7f32e978c000 rw-p 00019000 08:05 134634
7f32e978c000-7f32e97a2000 r-xp 00000000 08:05 531562
/lib/libresolv-2.11.1.so
7f32e97a2000-7f32e99a1000 ---p 00016000 08:05 531562
7f32e99a1000-7f32e99a2000 r--p 00015000 08:05 531562
7f32e99a2000-7f32e99a3000 rw-p 00016000 08:05 531562
7f32e99a3000-7f32e99a5000 rw-p 00000000 00:00 0
7f32e99a5000-7f32e99a7000 r-xp 00000000 08:05 523515
/lib/libkeyutils-1.2.so
7f32e99a7000-7f32e9ba6000 ---p 00002000 08:05 523515
7f32e9ba6000-7f32e9ba7000 r--p 00001000 08:05 523515
7f32e9ba7000-7f32e9ba8000 rw-p 00002000 08:05 523515
7f32e9ba8000-7f32e9baf000 r-xp 00000000 08:05 134268
/usr/lib/libkrb5support.so.0.1
7f32e9baf000-7f32e9dae000 ---p 00007000 08:05 134268
7f32e9dae000-7f32e9daf000 r--p 00006000 08:05 134268
7f32e9daf000-7f32e9db0000 rw-p 00007000 08:05 134268
7f32e9db0000-7f32e9dd4000 r-xp 00000000 08:05 132675
/usr/lib/libk5crypto.so.3.1
7f32e9dd4000-7f32e9fd4000 ---p 00024000 08:05 132675
7f32e9fd4000-7f32e9fd5000 r--p 00024000 08:05 132675
7f32e9fd5000-7f32e9fd6000 rw-p 00025000 08:05 132675
7f32e9fd6000-7f32e9fed000 r-xp 00000000 08:05 527976
/lib/libnsl-2.11.1.so
7f32e9fed000-7f32ea1ec000 ---p 00017000 08:05 527976
7f32ea1ec000-7f32ea1ed000 r--p 00016000 08:05 527976
7f32ea1ed000-7f32ea1ee000 rw-p 00017000 08:05 527976
7f32ea1ee000-7f32ea1f0000 rw-p 00000000 00:00 0
7f32ea1f0000-7f32ea265000 r-xp 00000000 08:05 523504
/lib/libgcrypt.so.11.5.2
7f32ea265000-7f32ea464000 ---p 00075000 08:05 523504
7f32ea464000-7f32ea465000 r--p 00074000 08:05 523504
7f32ea465000-7f32ea468000 rw-p 00075000 08:05 523504
7f32ea468000-7f32ea504000 r-xp 00000000 08:05 134182
/usr/lib/libgnutls.so.26.14.12
7f32ea504000-7f32ea703000 ---p 0009c000 08:05 134182
7f32ea703000-7f32ea709000 r--p 0009b000 08:05 134182
7f32ea709000-7f32ea70a000 rw-p 000a1000 08:05 134182
7f32ea70a000-7f32ea717000 r-xp 00000000 08:05 132150
/usr/lib/liblber-2.4.so.2.5.4
On 03/29/2011 03:00 AM, Markus Neteler wrote:
> On Tue, Mar 29, 2011 at 8:27 AM, Markus Metz
> <markus.metz.giswork at googlemail.com>  wrote:
>> If you ran make in the v.buffer directory and afterwards configure,
>> make and make install in /usr/local/src/grass6_devel, you would end up
>> with v.buffer2.
>> 1. run configure, make, but not make install in /usr/local/src/grass6_devel
>> 2. run make in the v.buffer directory, watch out for errors to make
>> sure it compiles all right
>> 3. run make install in /usr/local/src/grass6_devel, but not again
>> configure and/or make
>> 4. that should give you the original v.buffer
> An alternative: simply modify
>    vector/Makefile
> to point to v.buffer and not v.buffer2...
> Markus
