[GRASS-user] Defining Environment variable for WinGRASS
Luisa Peña luisapena1979 at gmail.com
Thu Mar 31 14:00:49 EDT 2011
Hi Glynn
For instance if I define GDAL_DATA like that, If in the same script I run
grass.Popen(<command to external gdal executable) is  that defined GDAL_DATA
path applicable?
Thanks
2011/3/31 Glynn Clements <glynn at gclements.plus.com>
> Luisa Peña wrote:
> > Is it possible to define a Environmental variable for Windows, like
> > GDAL_DATA, like this in a Python Script?
> > os.environ['GDAL_DATA'] = <PATH>
> > Is this possible? does this work?
> Yes.
> However, as each process has its own environment, it only affects the
> process running the script and any child processes spawned from the
> script. You can't modify the environment of other processes, e.g. the
> process which invoked the script.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110331/b51dc8fb/attachment.html
