[GRASS-user] v.to.rast gives empty raster layer
Hanlie Pretorius
hanlie.pretorius at gmail.com
Tue May 3 02:11:10 EDT 2011
Hi Maris,
Thanks, your suggestion worked. With the region's resolution set to
5m, I got some output.
Regards
Hanlie
2011/5/2, Maris Nartiss <maris.gis at gmail.com>:
> g.region vect=contours_20m
> Also 20x20m cells wouldn't be too large?!?
> Maris.
> 2011/5/2, Hanlie Pretorius <hanlie.pretorius at gmail.com>:
>> Hi,
>> I'm working in GRASS 6.4.1 on Windows XP.
>> I want to use r.surf.contour to convert contour lines into a DEM.
>> However, I first need to convert my vector contour lines into raster
>> contour lines. My region is set to the contours_20m vector layer, with
>> a 20m resolution.
>> v.to.rast --overwrite input=contours_20m output=contours_20m use=attr
>> column=HEIGHT
>> Loading data...
>> Reading features...
>> Writing raster map...
>> Converted areas: 0 of 0
>> Converted points/lines: 1593 of 1593
>> v.to.rast complete.
>> r.info for the result is:
>> | Layer: contours_20m at CDNGI_DEM Date: Mon May 02 14:18:00 2011
>> | Mapset: CDNGI_DEM Login of Creator: hanlie
>> | Location: SA_Lo_29E
>> | DataBase: F:\grassdata
>> | Title: Labels ( contours_20m at CDNGI_DEM )
>> | Timestamp: none
>> | Type of Map: raster Number of Categories: 0
>> | Data Type: DCELL
>> | Rows: 1772
>> | Columns: 1750
>> | Total Cells: 3101000
>> | Projection: Transverse Mercator
>> | N: -3121229.69982072 S: -3156672.30728643 Res:
>> 20.00147148
>> | E: -32474.90929218 W: -67483.27873573 Res: 20.00478254
>> | Range of data: min = 1620 max = 2460
>> | Data Source:
>> | Vector Map: contours_20m at CDNGI_DEM in mapset CDNGI_DEM
>> | Original scale from vector map: 1:1
>> | Data Description:
>> | generated by v.to.rast
>> | Comments:
>> | v.to.rast input="contours_20m at CDNGI_DEM" layer=1
>> type="point,line,ar\
>> | ea" output="contours_20m at CDNGI_DEM" use="attr" column="HEIGHT"
>> value\
>> | =1 rows=4096
>> As you can see from the number of categories (0), there is no
>> information in this raster file.
>> Can someone perhaps help me figure out why this happens?
>> Thanks
>> Hanlie
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
