[GRASS-user] DEM resolution from r.surf.contour
Hanlie Pretorius
hanlie.pretorius at gmail.com
Wed May 4 04:48:54 EDT 2011
I'd like to ask a question related to another question I was asking
recently about converting contour vectors to rasters and creating a
DEM from the raster contours using r.surf.contour.
My supplied vector contour layer has 20m intervals between contour
lines. When I convert this to raster, the smallest region resolution I
can use is 5m, otherwise v.to.rast runs out of memory.
When I use r.surf.contour to create the DEM from the raster, which
region resolution makes sense then? I set it to 20m because of the
contour interval, but I'm starting to think that's not the best option
because the interpolation between two contour lines should be as fine
as possible.
Any thoughts?
Thanks
Hanlie
