[GRASS-user] i.rectify update in 6.4
Markus Metz markus.metz.giswork at googlemail.com
Mon May 9 12:03:42 EDT 2011
Hi all,
the image rectification tool i.rectify has been updated in GRASS 6.4
as of r46222, after extensive testing in 6.5 and 7.0. Scripts work as
before, but should execute faster.
There are new options, one to select the resampling method (nearest,
bilinear, bicubic), one to set the target resolution, and one to
control memory usage of the module. These options are similar to
r.proj, which performs conceptually similar operations, namely
translating coordinates and fetching (resampling) the corresponding
pixel from the source image.
Enjoy,
Markus M
