[GRASS-user] Re: g.extension and GRASS 6.4.1
Luca Casagrande luca.casagrande at gmail.com
Tue May 10 16:26:11 EDT 2011
Thanks Markus for your answer!
After updating g.extension, the error message is this:
GRASS 6.4.1 (concessioni):~ > g.extension extension=r.stream.basins
svnurl=https://svn.osgeo.org/grass/grass-addons
Fetching <r.stream.basins> from GRASS-Addons SVN (be patient)...
A    r.stream.basins/main.c
A    r.stream.basins/description.html
A    r.stream.basins/global.h
A    r.stream.basins/catchment.c
A    r.stream.basins/io.c
A    r.stream.basins/Makefile
Estratta revisione 46230.
Compiling <r.stream.basins>...
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/include/grass
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/bin
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/etc
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/driver
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/driver/db
mkdir -p
/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/fonts
make OBJ.x86_64-unknown-linux-gnu
make[1]: Entering directory
`/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/r.stream.basins'
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
make[1]: Leaving directory
gcc -I/opt/grass/include -I/opt/grass/include
-I/home/luca/Dropbox/gis/dati/grass/concessioni/PERMANENT/.tmp/linux-547q.site/11122.0/dist/include
-O2    -I/usr/include/gdal -I/usr/include    -DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/io.o -c io.c
In file included from /opt/grass/include/grass/vect/digit.h:3:0,
                 from /opt/grass/include/grass/Vect.h:4,
                 from global.h:6,
                 from io.c:1:
/opt/grass/include/grass/vect/dig_structs.h:22:21: fatal error: ogr_api.h:
No such file or directory
compilation terminated.
make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Errore 1
ERRORE: Compilation failed, sorry. Please check above error messages.
Is it still related to GRASS or am I missing some packages?
Thx
Luca
View this message in context: http://osgeo-org.1803224.n2.nabble.com/g-extension-and-GRASS-6-4-1-tp6348794p6349403.html
Sent from the Grass - Users mailing list archive at Nabble.com.
