[GRASS-user] Re: g.extension and GRASS 6.4.1
William Kyngesburye woklist at kyngchaos.com
Thu May 12 09:42:19 EDT 2011
On May 12, 2011, at 7:17 AM, Markus Neteler wrote:
> sh: /usr/local/grass-6.4.2svn/tools/g.html2man/g.html2man: No such
> file or directory
> which is related to
> http://trac.osgeo.org/grass/changeset/46243
> The only solution will be
> - check if $(INSTALL_DATA)/tools/g.html2man/g.html2man is installed,
> - otherwise use $(GRASS_HOME)/tools/g.html2man/g.html2man
> No idea how to write that in a Makefile...
Oops, copied the wrong variable name.  It should be MODULE_TOPDIR, just like in html.make.
Fixed in r46445/r46446.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
