[GRASS-user] Re: i.atcorr output
Elena Mezzini
elena.mezzini at gmail.com
Fri May 13 12:09:19 EDT 2011
I had the same problem.
I don't know where your input data come from.
Now I know that it works if you use i.landsat.toar to calculate TOA
reflectance from DN images and then use these data as input files in
i.atcorr: you have also to use the flags -r (because of reflectance input)
and -f (because you need floating output).
I hope it will work!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-output-tp5352856p6359945.html
Sent from the Grass - Users mailing list archive at Nabble.com.
