[GRASS-user] g.extension_PROBLEM_UBUNTU_10.04
Matteo Mura
mur.teo at gmail.com
Sat May 14 06:34:08 EDT 2011
Thank you for you answer Mark,
yes, you are all right because my Ubuntu version (downloaded from ubuntu gis repository) is:
GRASS 6.4.0 (location):~ > g.version
GRASS 6.4.0 (2010)
instead your snapshot, if i remember, is written for the 6.4.2.
how can i update my GRASS version to your snapshot or how can i run g.extension correctly on mine?
i wait your help, please
Il giorno 14/mag/2011, alle ore 11.10, Markus Neteler ha scritto:
> On Sat, May 14, 2011 at 10:59 AM, Matteo Mura <mur.teo at gmail.com> wrote:
>> Hello everybody
>> i'm using ubuntu 10.04 and i've installed GRASS following the instructions of this page http://grass.osgeo.org/grass64/binary/linux/snapshot/ .
> When did you download it? I forced recreation on 12-May-2011 to
> include (almost) latest g.extension fixes.
>> I'm trying to install an addon with g.extension but the result is the following message:
>> (Sat May 14 10:49:23 2011)
>> g.extension extension=r.basin svnurl=https://svn.osgeo.org/grass/grass-addons/ prefix=$GISBASE
>> Fetching <r.basin> from GRASS-Addons SVN (be patient)...
>> A r.basin/r.basin1.gif
>> A r.basin/r.basin2.gif
>> A r.basin/r.basin.py
>> A r.basin/description.html
>> A r.basin/Makefile
>> Estratta revisione 46265.
>> Compiling <r.basin>...
>> mkdir: impossibile creare la directory "/build": Permesso
>> negato
>> mkdir -p /build/buildd/grass-6.4.0/bin.x86_64-pc-linux-gnu
>> make: *** [/build/buildd/grass-6.4.0/bin.x86_64-pc-linux-
>> gnu] Errore 1
> To me that indicates that you use an Ubuntu version and
> not the snapshot version since you should get a different
> error :) Please verify first that you run the right GRASS version,
> then we'll fix the rest.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110514/0fcf1196/attachment.html
