[GRASS-user] g.extension_PROBLEM_UBUNTU_10.04
Matteo Mura
mur.teo at gmail.com
Sat May 14 08:53:39 EDT 2011
Ok Markus,
i've found your script "grass-run.sh", i try to launch it (as a root) and i get this:
matteo at ubuntu:/$ '/usr/local/grass6.4.2svn-x86_64-unknown-linux-gnu-12_05_2011/etc/grass-run.sh'
If you wish to resize the X monitor, do so now. Window size is
locked while interactive modules are running.
"" complete. Press <enter> to continue.
matteo at ubuntu:/$
i press enter but i get nothing,
where am i wrong?
Matteo
Il giorno 14/mag/2011, alle ore 13.25, Markus Neteler ha scritto:
> On Sat, May 14, 2011 at 12:34 PM, Matteo Mura <mur.teo at gmail.com> wrote:
>> Thank you for you answer Mark,
>> yes, you are all right because my Ubuntu version (downloaded from ubuntu gis
>> repository) is:
>> GRASS 6.4.0 (location):~ > g.version
>> GRASS 6.4.0 (2010)
>> instead your snapshot, if i remember, is written for the 6.4.2.
>> how can i update my GRASS version to your snapshot
> Did you actually *install* the snapshot? Then you should have
> it available. Just select the right GRASS start script on your
> computer.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110514/2f7a1dcc/attachment.html
