[GRASS-user] nviz...3D Raster
Michael Morin mmorin at cassblue.com
Sat May 14 21:27:45 EDT 2011
Hello techies,
I have a 7.5 min SDTS grid that I exported from ESRI Arcview as an ASCII Arc/Info GRID.  I imported the GRID into Grass...used Elevation Color map and all works fine.  I invoke NVIZ using the same raster as the elevation image and I get a blank in my nviz window....error in Command Window is the following:
(Sat May 14 20:11:02 2011)
nviz elevation=salsburydem at PERMANENT
Raster map <salsburydem at PERMANENT> is outside of current region. Load failed.
Loading raster map <salsburydem at PERMANENT>...
Error finding range
I am new to Grass having been and ESRI guy for 30 yrs so I am wondering what I might be doing wrong to get this 3D surface to draw?
I thank you all in advance.
Bonjour,
Michael D. Morin
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110514/2d6a363a/attachment.html
