[GRASS-user] ps.maps: quality of rastermaps
Johannes Radinger JRadinger at gmx.at
Sun May 15 07:23:24 EDT 2011
Am 14.05.2011 um 02:57 schrieb Glynn Clements:
> Johannes Radinger wrote:
>> I include a rastermap in ps.maps via:
>> raster raster_map
>> it seems that the resolution/quality properties how the rastermap
>> is included is very low or any smoothing filter is used. I just want
>> really sharp raster cells instead of kind of fuzzy ones (see
>> attached picture). Is that somehow possible to change that?
> The blurring has nothing to do with ps.map. It's caused by the
> rendering of the resulting PostScript file.
> To avoid it, ensure that anti-aliasing is disabled in whichever
> program you're using to render the PostScript.
Oh thank you Glynn, I didn't thought about that option that it is a
rendering issue of the PostScript. It is just a setting issue in the
postscript viewer :)
/j
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
