[GRASS-user] Vector point from EXIF GPS data
Juan Miguel Garijo saldinet at yahoo.es
Sun May 15 13:31:28 EDT 2011
Hello,
This is my 'amateur' solution:
def getXYfromFoto(foto):
  proc=subprocess.Popen('exif -mt GPSLatitude '+foto,
shell=True,stdout=subprocess.PIPE)#foto: is the route to a jpg image from a
camera Sony  DSC-HX5V
  stdout_value = proc.communicate()[0]
  da=stdout_value[0:len(stdout_value)-1]
  sp=da.split(', ')
lat=float(sp[0].replace(',','.'))+float(sp[1].replace(',','.'))/60+float(sp[2].replace(',','.')[0:5])/3600
  print lat
  proc2=subprocess.Popen('exif -mt GPSLongitude '+foto,
  stdout_value = proc2.communicate()[0]
  da2=stdout_value[0:len(stdout_value)-1]
  sp2=da2.split(', ')
lon=float(sp2[0].replace(',','.'))+float(sp2[1].replace(',','.'))/60+float(sp2[2].replace(',','.')[0:5])/3600
  print lon
  proc3=subprocess.Popen('exif -mt GPSLongitudeRef '+foto,
  stdout_value = proc3.communicate()[0]
  da3=stdout_value[0:len(stdout_value)-1]
  print da3
  if da3[0:1]=='W':
    lonLat='"-'+str(lon)+' '+str(lat)+'"'
  else:
    lonLat='"'+str(lon)+' '+str(lat)+'"'
  print lonL #in wgs84
  proc4=subprocess.Popen('echo '+lonLat+' | m.proj -i --quiet',
shell=True,stdout=subprocess.PIPE)#GRASS must be running, in my case eur50
datum.
  stdout_value = proc4.communicate()[0]
  da4=stdout_value[0:len(stdout_value)-1]
  print 'da4'
  print da4
  pse=da4.split(' ')
  XY=pse[0].replace('\t',',')
  print 'XY'
  print XY
  return XY# in UTM eu50 30N
hope usefull for you
Juan M. Garijo
De: Joshua Arnott <josh at snorfalorpagus.net>
Para: grass-user at lists.osgeo.org
Enviado: sáb,14 mayo, 2011 16:55
Asunto: [GRASS-user] Vector point from EXIF GPS data
Hi everyone,
Has anyone tried to import the GPS data stored in a JPEG's EXIF metadata into
GRASS? I've had some luck, but the system I've come up with is very clunky
(mixture of python pexif module and then m.proj to assist import). I'm wondering
if anyone has come across anything more robust, maybe as a shell script with
jhead?
Josh.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110515/f2314bec/attachment.html
