[GRASS-user] g.extension_PROBLEM_UBUNTU_10.04
    Hamish
    hamish_b at yahoo.com
    Mon May 16 00:38:43 EDT 2011
Matteo wrote:
> thanks for your patience and good will, but finally: is there a way to
> install the addon "r.basin" on ubuntu 10.04 avoiding to make any trouble
> (because i'm not a advanced user) ?
ubuntu 10.04 with standard grass, grass-doc packages:  (6.4.0~rc5+39438)
not working yet, but how far I've gotten with it today:
# first fix from build server paths:
sudo sed -i -e 's+/build/buildd/.*+${INST_DIR}+' \
   /usr/lib/grass64/include/Make/Platform.make
# next create addon destination and grab g.extension from grass6.5 svn:
mkdir -p ~/.grass6/addons
svn export https://svn.osgeo.org/grass/grass/branches/develbranch_6/scripts/g.extension/g.extension -O ~/.grass6/addons/g.extension
echo "GRASS_ADDON_PATH=~/.grass6/addons" >> .bashrc
# log out & back in, start grass, check if g.extension shows up:
GRASS> g.extension --help
GRASS> g.extension ext=r.basin
Compiling <r.basin>...
mkdir -p /usr/lib/grass64/bin.x86_64-pc-linux-gnu
mkdir: cannot create directory `/usr/lib/grass64/bin.x86_64-pc-linux-gnu': Permission denied
make: *** [/usr/lib/grass64/bin.x86_64-pc-linux-gnu] Error 1
If I add -x to #!/bin/sh, ARCH_DISTDIR is indeed set at the end of the
make line for $MAPSET/.tmp/... so appears to want to use the version in
$GISBASE/include/Make rather than the one given at the end of the `make`
command line.
Hamish
