[GRASS-user] Re: Using temp files in Grass Script
Johannes Radinger JRadinger at gmx.at
Mon May 16 06:15:55 EDT 2011
Hello,
I found that thread about temporary maps...
e.g in my case in my python script i use:
    #Convert river from vector to raster format
    grass.run_command("v.to.rast",
                      input = "river_gen",
                      overwrite = True,
                      output = "river_raster",
                      use = "val",
                      value = res)
    #Thinning the rastarized river
    grass.run_command("r.thin",
                      input = "river_raster",
                      overwrite = True,
                      output = "river_raster_thin")
and here is the map river_raster only temporary for the thinning
process and the river_raster_thin is used for further calculations.
At the moment I have a g.remove to remove the river raster after
the thinning process but should I handle that with temporary files/maps
and if yes how is that exactly done in my python script?
/johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
