[GRASS-user] Error while exporting
    Markus Metz
    markus.metz.giswork at googlemail.com
    Tue May 17 11:02:33 EDT 2011
On Tue, May 17, 2011 at 3:09 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Metz wrote:
>> The NULL value of the reclass map is not recognized as NULL value, but
>> instead treated as a valid number.
>> This seems to be a bug in the GRASS library, specifically in
>> G_get_null_value_row() and has probably been around since GRASS 6.3.
> AFAICT, it has been around as long as G_get_null_value_row() has
> existed. G_get_null_value_row() returns the raw data, without any
> reclass applied.
> As it stands, this function probably isn't of much use.
Remove?
>> r.out.gdal can easily be fixed by not using G_get_null_value_row().
Fixed in r46324, r46325, r46326 (7.0, 6.5, 6.4.2, respectively).
Markus M
