[GRASS-user] Re: i.atcorr negative DEM
Elena Mezzini
elena.mezzini at gmail.com
Tue May 17 16:08:35 EDT 2011
On Tue, May 17, 2011 at 9:22 PM, Elena Mezzini
<elena.mezzini at gmail.com> wrote:
> Hi all,
> I'm once again in trouble with i.atcorr in GRASS6.5.svn.
> I notice that my output reflectance images are strange: there are some
> areas
> that are really bright and other that are really dark. Both seem to match
> with my DEM raster.
> Could there be problems with negative values in DEM?? I'm in a coastal
> area
> and there are some real altitude negative values.
i.atcorr (the 6S code it is using to be exact) should treat negative
elevation values as elevation = 0. It is debatable if this is correct,
but in theory i.atcorr should behave accordingly. Actually, I am not
sure about it's behaviour for negative elevation values...
You could set all negative elevation values to zero,
Ok, how can I do it?
run i.atcorr again and compare the results to the i.atcorr results using the
original DEM. If there are any differences that do not make sense,
please fill in a bug ticket.
Markus M
Thank you!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6374961.html
Sent from the Grass - Users mailing list archive at Nabble.com.
