[GRASS-user] Using a r.mapcalc expression in grass.mapcalc
Glynn Clements
glynn at gclements.plus.com
Thu May 19 12:26:08 EDT 2011
Jenny Turner wrote:
> I need to use this expression output=@input (input has labels and I want to
> export them so i need to do this). How can I do this in grass.mapcalc in
> Python? Does it accept @?
grass.mapcalc() is just a wrapper around r.mapcalc, so it supports
whatever r.mapcalc supports.
This:
grass.mapcalc('output = @input')
will work, but you wouldn't normally hard-code map names in a script.
grass.mapcalc() uses Python's string.Template class to simplify using
variables in expressions. This:
grass.mapcalc('$output = @$input', output = 'output', input = 'input')
is equivalent to the previous expression, but you can easily replace
the hard-coded names with variables, e.g.:
grass.mapcalc('$output = @$input', output = output, input = input)
Passing parameters which aren't used in the string is harmless, so you
can use Python's "**" syntax to pass a dictionary of parameters, e.g.
the "options" dictionary obtained from grass.parser():
grass.mapcalc('$output = @$input', **options)
The values of the output= and input= options will be substituted into
the expression.
