[GRASS-user] Possible to model exatmospheric radiation with r.sun?
Dylan Beaudette
debeaudette at ucdavis.edu
Sun May 22 20:38:08 EDT 2011
On Monday, May 16, 2011, Jonathan Greenberg wrote:
> Folks:
> I was wondering if there is a way to turn the atmosphere "off" in
> r.sun, and model a top of atmosphere radiation?
> --j
Hi Jonathan,
If you check out the metadata associated with the output from r.sun, you will
find the following: (note the "Extraterrestrial irradiance" entry)
r.info rad_beam.187
| Layer: rad_beam.187 Date: Thu Mar 24 17:17:43 2011
| Mapset: PERMANENT Login of Creator: dylan
| DataBase: /home/dylan/grass
| Title: ( rad_beam.187 )
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 1396
| Columns: 553
| Total Cells: 771988
| Projection: UTM (zone 10)
| N: 4235950 S: 4221990 Res: 10
| E: 697230 W: 691700 Res: 10
| Range of data: min = 4492.042 max = 7758.583
| Data Description:
| generated by r.sun
| Comments:
| Day [1-365]: 187
| Solar constant (W/m^2): 1367
| Extraterrestrial irradiance (W/m^2): 1321.303439
| Declination (rad): 0.396193
| Latitude min-max(deg): 38.1250 - 38.2500
| Sunrise time min-max (hr.): 4.72 - 4.72
| Sunset time min-max (hr.): 19.28 - 19.28
| Time step (hr.): 0.5000
| Linke turbidity factor: 3.0
| Ground albedo: 0.200
| r.sun -s elevin="ned10m" aspin="aspect10m" aspect=270 slopein="slope\
| 10m" slope=0.0 lin=3.0 alb=0.2 beam_rad="rad_beam.187" day=187 step=\
| 0.5 dist=1.0 numpartitions=1
> Jonathan A. Greenberg, PhD
> Assistant Project Scientist
> Center for Spatial Technologies and Remote Sensing (CSTARS)
> Department of Land, Air and Water Resources
> University of California, Davis
> One Shields Avenue
> Davis, CA 95616
> Phone: 415-763-5476
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dylan E. Beaudette
USDA-NRCS Soil Scientist
California Soil Resource Lab
http://casoilresource.lawr.ucdavis.edu/
