[GRASS-user] Re: i.atcorr returns all NULL values
Chemin, Yann (IWMI)
Y.Chemin at cgiar.org
Tue May 24 04:46:41 EDT 2011
Ah,
vis_list for 22 images in Iran, did not change those, the first value
was used to create a uniform map, used in the param file for that L5TM
image.
If you have n number of _MTL.txt files in the directory, you should be
able to set the array values n times over so that each image has a
visibility value to itself.
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork at googlemail.com]
Sent: Tuesday, May 24, 2011 12:52 PM
To: Chemin, Yann (IWMI)
Cc: grass-user at lists.osgeo.org; Elena Mezzini; Markus Neteler
Subject: Re: [GRASS-user] Re: i.atcorr returns all NULL values
On Mon, May 23, 2011 at 9:36 PM, Markus Neteler <neteler at osgeo.org>
wrote:
> Hi Yann,
> On Mon, May 23, 2011 at 5:07 AM, Chemin, Yann (IWMI)
<Y.Chemin at cgiar.org> wrote:
>> p192 r030 image of July 2003 of Italy (L5TM) successfully corrected
>> for band 1 and 2.
>> The following script works well in GRASS GIS Trunk SVN.
> (better send as attachment since a series of line breaks got broken)
>> # For i.atcorr scripting
>> vis_list=(10 10 8 9.7 15 8 7 10 10 9.7 12 9.7 7 12 12 12 3 15 12 9.7
>> 6 15) vis_len=${#vis_list[*]} echo $vis_len
> ... this is not clear to me: why so many values and where do they
> originate from? Since we have only 6 channels to work with...
Moreover, how can it be possible that visibility is different for
different channels of the same scene? From the documentation it seems
that visibility is related to aerosol concentration at 550nm which can
not possibility be different for different bands of the same scene.
Each created visibility map holds only one value r.mapcalc
expression="visibility=${vis_list[$i]}" --overwrite so why not just use
this visibility value as input in the parameter file instead of creating
a map where all cells have the same value?
Markus M
