Johannes Radinger wrote: > I tried as you recommended: > > make MODULE_TOPDIR='Applications/GRASS-6.5.app' If you set MODULE_TOPDIR on the command-line, it needs to be an absolute path. -- Glynn Clements <glynn at gclements.plus.com>
