[GRASS-user] Re: i.atcorr negative DEM
    Elena Mezzini
    elena.mezzini at gmail.com
    Tue May 24 11:51:49 EDT 2011
2011/5/24 Markus Neteler <neteler at osgeo.org>
> On Tue, May 17, 2011 at 10:57 PM, Elena Mezzini <elena.mezzini at gmail.com>
> wrote:
> > Elena Mezzini wrote:
> >> Markus Metz-2 wrote:
> >>> On Tue, May 17, 2011 at 10:08 PM, Elena Mezzini
> >>> <elena.mezzini at gmail.com> wrote:
> >>>> On Tue, May 17, 2011 at 9:22 PM, Elena Mezzini
> >>>>> Hi all,
> >>>>> I'm once again in trouble with i.atcorr in GRASS6.5.svn.
> >>>>> I notice that my output reflectance images are strange: there are
> some
> >>>>> areas
> >>>>> that are really bright and other that are really dark. Both seem to
> >>>>> match
> >>>>> with my DEM raster.
> >>>>> Could there be problems with negative values in DEM?? I'm in a
> coastal
> >>>>> area
> >>>>> and there are some real altitude negative values.
> >> g.region rast=dem_sross_srtm
> >> r.mapcalc "dem_sross_srtm_pos = if(dem_sross_srtm < 0, 0,
> dem_sross_srtm)"
> > No differences between negative and positive values...
> What do you mean precisely?
> I mean that i.atcorr automatically considers negative values equal to 0. So
the results of i.atcorr with negative values or with negative values made
equal to zero are the same.
So I still have problem with all the bands of landsat probably due to DEM.
Elena
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110524/e729b707/attachment.html
