[GRASS-user] Re: [GRASS-dev] LiDAR LAS import
Markus Metz
markus.metz.giswork at googlemail.com
Wed May 25 07:50:46 EDT 2011
On Wed, May 25, 2011 at 1:45 PM, <Doug_Newcomb at fws.gov> wrote:
> Yes!!!! Thank you Markus! Since you are using liblas 1.6.1 , I assume
> that this command can read the losslessly compressed .laz format?
> As long as libLAS is compiled with laszip support, yes (tested and
working).
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110525/4191ca15/attachment.html
