[GRASS-user] Limits on computation
Tue May 31 11:32:18 EDT 2011
Monica Buescu wrote:
> Just one question aboht that limit of number of cells: is that limit
> applicable to CELL or DCELL?
Both.
The few modules which read an entire map into memory will also be
limited by available memory and address space, which will affect DCELL
more than CELL or FCELL. However:
1. Memory consumption is determined by whether the module reads the
data as CELL/FCELL/DCELL, not how it's stored on disk.
2. Such modules tend to be algorithmically complex, so execution time
becomes an issue long before memory availability does.
