[GRASS-user] Hardware config/limits
nunosousa84
nuno_sousa_1984 at hotmail.com
Tue May 31 12:25:25 EDT 2011
I've noticed that i have serious problems dealing with large raster maps and
some GRASS commands in Grass plugin, like r.surf.contour, shaded relief,
some raster calcs, etc... Im using 1 by 1 resolution, maybe it is a bit
exagerated, but even at 5 by 5 the calculation process is very slow. Im
using a Intel Core 2 Duo E8400 and 4Gb 8500mhz DDR2 Memory. Im about to do
an upgrade, should i opt for 8Gb memory, or i better opt for a good CPU
(maybe quad core)? Whats your experience dictates to improve performance?
The strange thing is that Ubuntu System Monitor says only one core is at
100% full capacity but the other is only 20%. Ans memory usage is only
700Mb, so whats causing all this lag and slow calc, the bar almost dont
moves? Im using Ubuntu 10.04 32bits.
Thank you
Nuno
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Hardware-config-limits-tp6423485p6423485.html
Sent from the Grass - Users mailing list archive at Nabble.com.
