[GRASS-user] Using r.resamp.stats
Glynn Clements
glynn at gclements.plus.com
Tue May 31 17:05:55 EDT 2011
Jenny Turner wrote:
> I have one question regarding null values: I'm using r.resamp.stats with
> method average. My question is, if I have a Target pixel based on 10 null
> values and 1 non-null value, the target pixel will be based only on valid
> pixel? I mean, it only requires at least 1 value to produce an output value?
Without -n, the aggregate is computed over the non-null values; if all
values are null, the result will be null.
With -n, if any value is null, the result will be null.
