[GRASS-user] Re: r.in.gdal oddity
Markus Metz
markus.metz.giswork at googlemail.com
Tue Nov 1 10:33:45 EDT 2011
On Tue, Nov 1, 2011 at 2:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Oct 31, 2011 at 9:25 PM, Brian Oney <zenlines at gmail.com> wrote:
>> Yes, everything works great. Thanks again.
>> Ok, good to know. Yeah, the algorithm could be improved I guess. But, the
>> improvement that I would suggest is supposed to be the -l flag, right?
> Yes, that was the idea of the -l flag.
>> Just force it to be 180W and 180E... I thought (the -l flag) it is just a recent
>> addition to GRASS 6.4, so maybe it needs a some t.l.c...
> I run into the same problem recently (see my other posting) and didn't
> manage to import with -l. Using
> gdal_translate -a_ullr -180 90 180 -60 inmap outmap
> is a solution but it would be better to get -l working (since it should do
> the same). The code piece is
> /* constrain to geographic coords */
> if (flag_l->answer && G_projection() == PROJECTION_LL) {
> if (cellhd.north > 90.) cellhd.north = 90.;
> if (cellhd.south < -90.) cellhd.south = -90.;
this:
> if (cellhd.east > 360.) cellhd.east = 180.;
should probably be
if (cellhd.east > 180.) cellhd.east = 180.;
But I faintly remember some maps to cover 0, 360 instead of -180, 180.
Furthermore, a map spanning 170,190 (the datumline) should stay as is,
the correction is probably only necessary if E - W > 360, E - W as
provided by GDAL, before GRASS does any conversion.
Also, it may be safer to do the correction after the projection check
and optional creation of a new location, not before.
Markus M
> if (cellhd.west < -180.) cellhd.west = -180.;
> cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
> cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
> cellhd.ew_res3 = cellhd.ew_res;
> cellhd.ns_res3 = cellhd.ns_res;
> G_warning(_("Map bounds have been constrained to geographic "
> "coordinates. You will almost certainly want to check "
> "map bounds and resolution with r.info and reset them "
> "with r.region before going any further."));
> ... the warning is not particularly clear to me - "reset them" in this sense?
> Markus
