[GRASS-user] removing empty files from grass mapset
Markus Neteler neteler at osgeo.org
Wed Nov 2 19:52:08 EDT 2011
On Sat, Oct 29, 2011 at 2:45 PM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Dear all,
> I just remove 5,000 maps from a mapset using "g.remove -f map=mymap",
> and observed that, although the command worked fine, when I go under
> the directories (like .../Mapset/cell) I see there a lot of empty
> files (0 bytes), and the removed raster map filenames are still there.
> How can I remove that?
Can you please check the fcell/ directory, too?
There seem to be undeleted floating point maps.
Markus
