[GRASS-user] Re: European Datum 1950 is not saved in the region
information
Sophia Ratcliffe
sophiav at gmail.com
Fri Nov 4 09:18:53 EDT 2011
Thank you for investigating.
I have the same problem with another projection for the Finland Uniform
Coordinate System:
I've set up a location by selecting the EPSG code 2393 and when I run
g.region -p I get the following:
projection: 99 (Transverse Mercator)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: international
I get the same result if I create the location using a .prj file:
PROJCS["KKJ / Finland Uniform Coordinate
System",GEOGCS["KKJ",DATUM["D_KKJ",SPHEROID["International_1924",6378388,297]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Is there any way to set the datum once the location has been created?
Many thanks for your help,
Sophie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/European-Datum-1950-is-not-saved-in-the-region-information-tp6958890p6962707.html
Sent from the Grass - Users mailing list archive at Nabble.com.
